In my usual detail mode dual lister configuration, suppose I make both listers point to the same folder. Then I grab one of the files in one lister with the right mouse button (suppose it is called foo.txt) and drag it to the other lister. Then I get a window like:
COPY AS: Enter the new filename or rename pattern.
OLD: foo.txt
NEW: foo.txt
Suppose I click on the NEW field and change the foo.txt to foobar.txt and click OK. DOpus will obligingly create a copy of foo.txt called foobar.txt in the same folder containing foo.txt. Strangely enough, I do this operation rediculously often, usually just before modifying a file when I want to preserve an easy way to revert back to the original. Of course there are many other ways of making backups and reverting to earlier versions, but I often find this way useful when one of those ways has not been set up or in addition to them. My question is "is there a way to do this operation easily without setting up both listers to point to the same place. Ideally I would be able to do this from the right click context menu or equally convenient, from a toolbar button.
Thanks in advance for any ideas on how to do this.
~Paul Mennen
