Create separate RARs from selected items, then delete them
in 2019 I post That. Then Dear Leo give me this script. This script works fine but needs some tweaks. This script Leaves the original file. But I want to move the original file into the rar file. Because the Original file Occupies double space in my Hard Drive. Here is the script:
function OnClick(clickData)
	var source = clickData.func.sourcetab;
	var cmd    = clickData.func.command;
	var work   = false;
	cmd.deselect = false; // Leave source files selected.
	cmd.ClearFiles();
	for (var e = new Enumerator(source.selected); !e.atEnd(); e.moveNext())
		var f = e.item();
		if (IsEmptyDir(f))
			var arcName = f.Path + "\\" + f.name_stem_m + ".rar";
			if (!DOpus.FSUtil.Exists(arcName))
				work = true;
				cmd.AddLine("CreateFolder NAME=\"" + arcName + "\" ARCHIVE=.rar READAUTO=no NOUPDATESETTINGS");
		else
			work = true;
			cmd.AddLine("Copy FILE=\"" + f.RealPath + "\" TO=\"" + f.Path + "\" ARCHIVE=.rar CREATEFOLDER=\"" + f.name_stem_m + ".rar\"");
	if (work)
		cmd.Run();
function IsEmptyDir(item)
	if (!item.is_dir)
		return false;
	var fe = DOpus.FSUtil.ReadDir(item.RealPath);
	return fe.complete;
I don't generally recommend this because it may not handle all error situations, and leave you with a corrupt/incomplete archive and the source files deleted as well, but if you really want to, you can add this line:
		cmd.AddLine("Delete QUIET FILE=\"" + f.RealPath + "\"");
Like this:
	var work   = false;
	cmd.ClearFiles();
		var f = e.item();
		if (IsEmptyDir(f))
				work = true;
		else
			work = true;
	if (work)
		cmd.Run();
	if (!item.is_dir)
		return false;
	return fe.complete;
But, personally, I would archive things, then delete them separately.
I'd let WinRAR do the job and take the responsibility for deleting, it's a built-in feature:
Available via command line as well.
Thank you so much lxp. Is That Possible to create a button to run the WinRAR program with check these 2 option
  1. Put each file into a separate archive
  2. Delete Files after archiving
