GP SoftwareTwitter
Opus FAQsManualCommandsObjects
Crystal Project OPUS MOD by SigmaTau
Crystal Project OPUS MOD v0.3
by SigmaTau
Click here to see big
The zip file contains:
  • crystal_project_OPUS-MOD.dis: 1878 Large and Small Toolbar Icons for DOpus 9
  • crystal_project_OPUS-MOD1.jpg: Info image
  • crystal_project_OPUS-MOD2-640.jpg: Preview image
The Icons look much better if you disable the highlighting effect:
  • Go to Settings -> Preferences -> Display -> Toolbars
  • Set Image highlighting effect to None
Version history:
  • v0.1 (jun.2008): 1878 Icons in 20x20, 32x32
  • v0.2 (jul.2008): 1878 Icons in 20x20, 32x32 SOME BUGFIX
  • v0.3 (jul.2008): 674 actions Icons in 20x20, 32x32 SOME BUGFIX
  • v0.3 (jul.2008): 912 apps Icons in 20x20, 32x32 SOME BUGFIX
  • v0.3 (jul.2008): 202 devices Icons in 20x20, 32x32 SOME BUGFIX
  • v0.3 (jul.2008): 98 filesystems Icons in 20x20, 32x32 SOME BUGFIX
  • v0.3 (jul.2008): 250 mimetypes Icons in 20x20, 32x32 SOME BUGFIX
Download
http://www.x-2-1.de/~opus/actions-crystal_project_OPUS-MOD_v0.3.zip
http://www.x-2-1.de/~opus/apps-crystal_project_OPUS-MOD_v0.3.zip
[u]http://www.x-2-1.de/~opus/devices-crystal_project_OPUS-MOD_v0.3.zip
[/u]
http://www.x-2-1.de/~opus/filesystems-crystal_project_OPUS-MOD_v0.3.zip
http://www.x-2-1.de/~opus/mimetypes-crystal_project_OPUS-MOD_v0.3.zip
Thanks for the submission.
I've converted it to a zip file and added it to your post so that it's hosted here rather than with that annoying rapidshare site.
Thanks! Really nice!
Thank you, they look great.
Not to be a a killjoy, but the preview pages showing the icons here on the post are NOT all the same as the icon packages actually included in the download, many icons are there - and I know some were 'added' after the original post, but many seem to be missing... Also, various icons appear not only between sets, but also many times within the same set, some up to four times in the same set just with different names...
I haven't tested Opus startup lag due to excessive number of icons, but I'd say many of them could be trimmed down and perhaps better ligned up with 'default' icon "names" so that ppl might be able to use the packs as pseduo-drop in replacements.
I'm not even sure if all of these are from Everaldo...?
I tried installing them but nothing changes on my icon set. Other icon sets I have I can switch through, and they change, but trying this set does nothing on my end, I wonder why?
Probably the same as this:
[Square Colored OPUS MOD by SigmaTau)
Thanks Leo for the heads up
Keep the good job!
Your display file is missing and not one of the download sites it found.
