"Ctl L" size function & Trash Bin
These a pretty minor (I use to use alot on ver 12)
Ctl L function to get/refresh the size of folders - If you select a couple of folders or all it doesn't work. it just jumps up to the path window.
It works for individual selections but not for groups.
Also, if you are on the trash bin on the desktop and right-click to choose to open in Opus - it doesn't work and opens Explorer instead
The key has been changed to Ctrl-K in the default setup (already in v12).
Oh - I must have changed it or maybe it was in the earlier version 10 or 11, but thanks
Yes, Ctrl-L used to be the default. I think it changed in v12.
