CTRL Key (Keyboard Commands) not working in Dopus9
For some odd reason my ability to cut, paste, delete etc using the keyboard commands (eg. CTRL+C, CTRL+V) has stopped working in DOpus only. In all my other programs this ability works great but not in opus9. What am I doing wrong. Please and thank you for your help.
Do you have these command in "Customize" window, "Keys" tab :question:
If you go to Settings -> Customize -> Keys do you still see entries for Ctrl-C, etc.?
By default those hotkeys come from the Edit menu. If you've turned off the menu bar or deleted the Edit menu then you'll lose the hotkeys as well.
If you deleted the Edit menu on purpose because you only wanted to invoke the commands via hotkeys then you will need to create standalone hotkeys for them. You can do that from the Customize Keys dialog.
Ctrl-C should run Clipboard COPY
Ctrl-V should run Clipboard PASTE
Thank you! I did delete the Edit Menu as I use my own customized menus and thus... I have repaired this glitch, but not without your help. Thank you again!
