CTRL + mouse wheel to zoom - inverted?
Suddenly zoom using my mouse wheel is inverted. Scrolling down now zooms in, and scrolling up now zooms out. Zoom still works as expected (up=in, down=out) in Explorer.
Is this a DOpus thing or something else? Seems to have changed with the update to 12.17
You're right; the directions were swapped as a side-effect of changes to improve support for Surface touchpads.
We've fixed that for the next update. Thanks for reporting it!
