I have the following settings:
and
Selecting a file when I click in source/dest works like a charm, as it should per my settings in the first screenshot. And it even works with multiple files selected... as long as I don't use CTRL-click to make the selection.
When I CTRL-click (not using lasso, just CTRL-click) to select multiple files and then click in the left/right, the lister is not activated. Only the second click activates the lister. TAB works fine.
Steps to reproduce:
- Open a dual pane lister. Doesn't matter if vertical of horizontal.
- Select multiple files on the left lister pane using CTRL
- Click once in the right lister pane.
The right lister should be activated, but it isn't.
This happens only with a dual pane lister. Everything works fine between multiple windows.
Using v13.7.5b.
