I'm new to Directory Opus and I would like to check if I can reach my goal..
I would like to use the Default layout and save it on exit, like normal: saving opened folders and tabs.
But when I use a custom layout with different tabs and folder, I don't want it to be saved as the Default one on exit..
Right now the only way I found to do that is to open the default layout, then open the custom one, do what I need to do and close it BEFORE exiting completely, so before closing the default one, otherwise I would lose my default layout and I would have to configure it again..
I checked the options more than once and tried different things but maybe I'm missing something obvious..
thanks a lot!
It will block the default lister from being updated when you close a window which was opened as part of a layout.
Script code for reference (same as in the download above):
function OnInit(initData)
initData.name = "No default layouts";
initData.version = "1.0";
initData.copyright = "(c) 2020 Leo Davidson";
initData.url = "https://resource.dopus.com/t/custom-and-default-layouts-saves-on-exit/35079";
initData.desc = "Do not update the default lister when closing windows from a layout";
initData.min_version = "12.20";
function OnCloseLister(closeListerData)
if (closeListerData.lister.layout != "")
DOpus.Output(closeListerData.lister.layout);
closeListerData.prevent_save = true;
return false; // Do not block the lister from closing.
wow, thank you, I tested it for a while and it seems to work flawless.. the only little (very little) issue I found is that when I completely close Dopus from task bar with the custom layout, the next start tit will open the custom layout again. but as soon as I close the windows and open dopus again it loads the default layout..
Hope I was able to explain what I meant. and anyway it's not really as problem, because the default layout was saved correctly, so I'm happy with the solution.. Thank you very very much for the script you made, I really appreciated it!
I would like to use this thread to make another question, if possible; if it's a problem I can open a new one.. Is there a way to buy Directory Opus from bundles sites like Humble Bundle? I often see software bundles there..
