Hi,
I am trying to create a context menu command to MOVE selected folders and files while imposing a file-type filter.
For example, I want to:
- select a bunch of folders and files in the source pane.
- right-click and choose "MOVE selected ITEMS TO DESTINATION pane" (with the exception of .xlsx files).
I asked a similar question last week, except in that instance, I simply wanted to COPY the files and folders. The proposed solution from last week was to use Copy FILTER ~(*.xlsx) and this works like a champ.
However, I get the following undesired behavior if I use Copy MOVE FILTER ~(*.xlsx)
- If I use
Copy MOVE FILTER ~(*.xlsx)on a file (or files) the selected files are moved to the destination (as desired). - However, if I use
Copy MOVE FILTER ~(*.xlsx)on a folder, the folder (and its contents) are COPIED to the destination pane and the contents of the selected folder are MOVED, but the selected folder itself is not deleted from the source pane. That is, after the command is run, the selected folder winds up empty in the source pane, but it still exists in the source pane and I would like it gone. - In contrast, if I simply use
Copy MOVEon a selected folder, the folder and its contents are MOVED to the destination pane and the selected folder is "deleted" from the source pane (as desired).
As a shot in the dark, I also tried modifying the command to look like this:
Delete
but this does not delete the selected source folder either.
Any ideas as to where I've gone wrong?
Thank you.
