Hello, I have been using DOpus for a while now and it's great. I have some ideas for features that I would like to put out there, so here goes...
Customize Metadata Pane
You can customize everything in DOpus it seems - except the Metadata pane. I often don't need to see all the Metadata in the pane - so crowded! Often I only need a few key fields. Same goes for Metadata categories, don't need to see them sometimes. So, what would be cool:
- Under Preferences, select which Metadata elements to display in the pane
- Show/Hide Metadata Categories (Document Properties Heading, Picture Properties Heading etc.)
- Always expand/contract the accordion effect (except of course if the Show/hide categories is set to hide
Script Pane
It would be nice to have a docked pane or panel - like the viewer or metadata - that was essential a script dialog. That way it would always be present, no popup. Imagine the stuff one could put in that little box!
