Customize progress window
Is it possible to customize the progress window that is displayed when copying files?
Inmy case, Isomimtes copy 10+GB of data and in addition to the total file count that is displayed in the bottom half of the window, I'd like to see the total file size, amt already copied, and/oe the amt remaining.
thanks.
You can't customize the progress dialog beyond the minimal and large options, sorry.
I may be wrong but on older versions didn't it show the file size :question:
I cant remember but I am sure it showed either a count down or count of file size copied :question:
I would like it to have the option to be able to do this now if possible. :slight_smile:
