Customize thumbnails view?
How about a way to customize the thumbnails view? I'd like to be able to adjust which fields are displayed, e.g. to show the description, date, set the font size, etc. What do you think? Right now you can set the font size for the main thumbnail label but you don't have control over the size used for the other fields (file size, dimensions) and there's no way to set which fields are shown. Thanks.
Damien
I am interested in this issue, too :slight_smile:
Thumbnails is hard-coded to show you the image size, and the font is based on the main thumbnail font (just a smaller size).
Have a look at tiles mode instead - it can display thumbnails as well, and the information fields it shows are fully configurable.
Thanks Jon - that's exactly what I need! :smiley:
