Using the search function, I can find several examples on how to create mount/dismount buttons for Daemon Tools.
Unfortunately, they all refer to a DAEMON.EXE which does not exist on my current installation of Daemon Tools Pro. Any clues to help me out?
Try replacing Daemon.exe with DTAgent.exe
eg: "C:\Program Files (x86)\DAEMON Tools Pro\DTAgent.exe" -mount 0,{f}
That did the trick, thank you ever so much.
I think there's one complete set in the button section.
