I can't seem to default different args for the Filter box other than "realtime". Is it possible that some other settings in the default lister might override these? The reason I ask is that I set a default for "file", but when I close DO and relaunch, it's still set to files and folders.
I currently have "realtime files" in the arguments box. Is there a need to use a comma, semicolon?
What's odd is that when I first launch DO, I'll see the files icon for a split second but it gets replaced with the files and folders icon.
Nudel's method works fine for me too nate. Since you're not using the current version of Opus I went back and looked at the changes made in the latest release to see if there was anything related to the Fast Filter field but didn't see any.
Try pasting my Filter onto your toolbar while in Customize mode:
<?xml version="1.0"?>
<button display="icon" effect="gray" field_type="filter" hotkey="ctrl+Q" size="100">
<guid>{12FD6028-9E7C-46A1-8D40-E6ADA35B6081}</guid>
<label>Filter</label>
<tip>Directly enter a wildcard pattern to show files in the current Lister</tip>
<template>files,realtime,nopartial</template>
<function type="normal">
<instruction>Set FILTER</instruction>
</function>
</button>
(Copy all the XML to your clipboard, enter Customize mode, right-click an empty space on your toolbar and select Paste.)
