Default associated program for ftp links?
Hi,
inside a Thunderbird e-mail I clicked a URL link like this one:
ftp://ftp.xxxxxxxxxx.de/develper/xxxxxxxxx/windows/
This opened Windows Explorer showing the files inside this FTP directory as normal files.
Why in this case would not open Opus instead of Windows Explorer?
Explorer Replacement mode does not affect FTP; instead, you can make Opus the default FTP handler by turning on Preferences / Miscellaneous / Windows Integration / Make Directory Opus the default handler for FTP sites.
Hi jon, this option was already selected:
However, still Windows Explorer opens the FTP link.
Did you try turning it off and on again?
Yes, several times, and clicked 'Apply' and 'OK'-closed the Preferences dialog in between (I know the dirty tricks ... :wink:)
youtube.com/watch?v=nn2FB1P_Mn8
XD :wink:
