Hi, I've noticed flat mode automatically resets the column layout of the lister to the default name, size, type... set of columns. I've tried customizing either by saving my chosen layout via 'folder options' or saving it with lister layouts but it doesnt work, it keeps resetting to the default layout. Is there anywhere I could modify this default column layout for flat view?
in Preferences/Folders - Folder Formats you have Default Formats section which one have Flatview format. Try to configure columns for this Flatview format.
