I have set my default column sort by name. but sometimes, in a specific folder, to quickly find the newly created file, I click on the modified date column and when I go to some other folder, the changes have taken effect there also.
This even occurs with folder in entire drive, not only files. even the folders are set to modified date sort order. I think, changes made in the column sort must be local and not global unless there is any bug.
I am using dopus 13.12. is there any bug or the behavior is like this only?
