Default Group on Start up
Please tell me what settings to use so that DO always opens a specific tab Group when the program is started.
Thanks,
jdd
Is anyone able to help with this request?
Thanks,
jdd
Unfortunately Go NEW TABGROUPLOAD=xxx doesn't work as one might hope (it loads the group into an existing lister if there is one, and does nothing if there isn't one). I've just filed a feature request/bug report about that.
Meanwhile, I think your best bet is to use a saved Layout. The only drawback to this is that if you make changes to the tab group you'll also have to re-save the layout since I don't think there will be any connection between the two.
To make a layout, set up your lister how you want it to be, with the tab group in effect, then go to Settings -> Lister Layouts -> Save This Lister in the default menus and give the layout a name like My Start Layout.
Now go to Preferences / Startup and select Open a saved Lister layout, then select your layout from the drop-down list.
If you also want your layout to open when you double-click the desktop and/or double-click the tray icon then you can configure that under Preferences / Double-click / Desktop.
