Hi,
I have Win 10 x64 & the latest stable opus (11.16 x64)
For some reason when ever I launch DO the default lister does not open (i have saved a layout as the new default lister), I have tried saving the lister (called it Main) & tried that way ie in startup settings, that does not work either.
Any help would be grteatly appreciated
TIA
Sorry forgot to add wowrks fine if double clkick on desktop only does not work when using Win+E
What aspect of it goes wrong?
Win+E is a Windows hotkey to open a specific folder (e.g. My Computer in most versions of Windows) so if it's just that the wrong folder is opening then that is why.
Win+Shift+E is the default hotkey Opus sets up to open the Default Lister, but you can change it via the Customize window. Note that overriding Win+E itself may not work on Windows 10.
Thanks for replying
Previously when pressing win+e DO would open to my default lister (saved/created by myself) DO is set as explorer replacement for all.
When I double click on the desktop DO opens my saved default lister (left hand pane point to d: drive downloads folder, left pane opens this PC) this is exactly as it should be, however when I press win+e DO opens This PC in both panes, not my saved default lister.
Previously as in before updating to Windows 10, I presume.
Everything that's happening should be explained by my first reply if that is the case.
Thanks didn't know about win shift e yes you're right it's win 10 just it use to work in win 8.1 thnx for explaining
sorry where in the prferences menu? is the hotkey setup?
Settings > Customize Toolbars > Keys.
