Default starting dir
...sorry if this is a repost, but I simply couldn't find any trace of this, even is such an easy question...
How to set up a default starting dir for DOpus? (a route wich is opened when DOpus is started). By default, DOpus opens the last place visited, wich is not really good for privacy...
A while ago someone suggested shortcut commands like "C:\Programs\Directory Opus\dopus.exe" /cmd go c:\startingdir" but some time ago this function stopped to work (?)... Where can I turn off this goto-last-place-visited thingy in DOpus?
There are actually multiple ways built into Opus to control this depending on what features you're using (like saved Layouts)... but for you the quickest is probably to do the following:
Disable the Settings->Preferences->Layout->Opening Listers->Update Default Lister settings when Listers are closed option.
Open a Lister to the directory you want new Listers to always open to by default, then manually run the Settings->Set As Default Lister menu option.
done
