Default toolbars slider: add versions
You have a very cool slider in the "Default Toolbars" customization tab which highlights new menu buttons. However, it doesn't mention a specific DOpus version, so I can't select "Show everything since version X since that's the last time I checked my menus"
The version is shown as you move the slider.
Where?
When you are dragging the slider.
Oh, I see now, it only works when I click&hold, which I never did since I was just using a mouse wheel, that's more convenient vs having to hunt that tiny slider.
So then this should be more explicit in the informational text at the top or as some kind of permanent text on the slider itself
I didn’t even know the mouse wheel worked there. :slight_smile: Must be something the control handles automatically.
Yeah, the beauty of standard controls!
