Del key doesn't work in MTP folder
In the last beta 10.2.0.x, i notice that i cant delete files using del key in folder. I plug my galaxy S3 in MTP mode under win7.
alt+D for a new folder doesn't work either
Did these ever work? I doubt anything changed in the beta.
Proper MTP support is coming soon.
Because native MTP support is slower (sometimes 1min to display device and sdcard folders), i disable it.
Can you look at the del key please ?
Are these problems (freezing) solved in the latest beta?
i can say yes :wink:
Magnifique! :slight_smile:
Superbe !
