Hi,
Using Directory Opus 9.5.1.0.3624.x86 on Windows 7 Enterprise x86, I've found "Delete EMPTYRECYCLE" (assigned to a toolbar button) doesn't always empty the recycle bin(s) as expected. The conditions where it doesn't work, as far as I can tell, are listed below:
One or more partitions are accessed through a NTFS junction instead of a drive letter. IOW, they are mounted as folders, not drives. You can do that with Windows' Disk Management applet.
Files on such partitions have been deleted, and NO FILES from other partitions (those with a drive letter) have been deleted.
Under such conditions, pressing the button doesn't work. The files remain in the recycle bin afterward.
Note that both conditions have to be true. If a partition has a drive letter besides the NTFS junction access point, it doesn't qualify. (I.e., "Delete EMPTYRECYCLE" still works.) If there are files deleted from partitions with a drive letter, the command also works. In that case, all recycle bins are cleaned properly, including those on junctioned partitions.
I have several such partitions on my system, and the behavior is consistent with all of them.
Hope that's clear enough.
