Delete REMOVECOLLECTION issues
Hello guys!
I was using file collections during the last days and noticed strange things.
Updated to latest beta now to double check and only some minor things enhanced or got back to normal, so..
  1. First of all "Delete REMOVECOLLECTION" only seems to be working as expected if executed from the command bar. The very same original command on the "Collection" context menu only yields this:
    Clipboard Image (2)
    EDIT: This was with 12.6.1b, no more dialog with 12.6.3b, still mentioning this, because "Delete REMOVECOLLECTION" sometimes still does not work. No dialog now,
  2. Using "Delete REMOVECOLLECTION" and pressing CTRL-Z to undo that removal, gives a requester whether I'd like to delete the collection? Aehm, NO! o)
  3. Go REFRESH does not work reliably, most of the time it does nothing (recognizing removed items e.g.) Or even recognizing the whole file collection being removed. I can even select files in the non-existing file collection and have them previewed in the viewer bar after "refreshing".
  4. Dragging items into the collection will update a filedisplay showing the same collection, removing items will not trigger a refresh. EDIT: Oh sometimes it does! o)
  5. Dragging items into the collection, which already exist in there, gives a "Item already exists" dialog, with "Skip and Abort" option. Wondering whether this makes sense. Especially for a single item this is strange, since whether I hit skip or abort, the result is probably the same?! I get notified that this item is already in there, I don't know whether that helps or annoys.
  6. I am able to copy and paste drives (via context menu) from the "Computer" location into a file collection. I cannot access these entries ("system cannot find this path" error) or delete them from there ("an unknown error occurred" error).
No special paths involved here, no UNC, no symlinks, all regular folders and files on local drive.
Thanks! o)
