I am trying to use the delete filter for the first time. I want to delete empty folders.
I select empty folders, enable filtered delete with "Set DELFILTER=Toggle", push Del, then I try the filter:
But nothing is deleted.
Using the same filter for other operations works well. Please try to reproduce. I am using the latest version, 12.6.
Leo
August 10, 2017, 9:10am
2
Does it work for you if you use Shift + Del to bypass the recycle bin?
(Please try with some test folders first in case it deletes more than expected, with any delete/filter test.)
Yes, it works. Does this means there isn't a bug?
Leo
August 10, 2017, 7:58pm
4
It may still be a bug, but I wanted to make sure we're seeing the same thing.
Need to investigate more to find out exactly where the problem is, but I think it should work with both even if it's only working with non-recycle bin at the moment.
Birba
December 9, 2018, 9:51am
5
Some news? I have the same problem… (DOpus 12.10.4)
But does the delete filter not work in folder tree?
Thanks
