Descript.ion override
Currently you can use either the Descript.ion or the NTFS comment system. I have a need to use the Descript.ion files for some folders but If I enable the
2021-02-25_15-12-29
option then I am not able to see the NTFS comments. Is it possible to have an option to use the Descript.ion file IF one exists, otherwise use the NTFS comments?
Thank you
Bob Gregory
There isn't, I'm afraid. Opus can either be configured to use one or the other, but not both in different places.
