Are we able to chose what the description column calculates? I usually like the column and have it on by default. However when I open a large folder of text files it will go through and check the file type for each one. I don't find the output useful but I don't want to turn off the column.
So I find I have to remove the column and re-load the lister.
I would love a page in the option to pick what calculations it runs, so i can turn off the expensive ones i don't need.
cheers
