Good day to everyone. First I want to congrat to the DOpus Team for doing such a piece of work!!! Great job!!!
Now, this is the problem that I'm facing it, when I try to make a button that run the following:
First, I have to clear some things. In my laptop, because I owned (I know that Everything is running all the time), I use Everything with DOpus, in order to do a search with Everything and import files to a collection, I only use this command that works great:
@runmode hide
@keydown:none
"{alias|programfiles}\Everything\es.exe" {dlgstring|Opciones:\n-p:Incluir a los resultados archivos relacionados\n-n num:La cantidad maxima de resultados mostrados\n-i:Realizar una busqueda sensitiva entre mayusculas y minusculas\n-w:Busqueda por palabras completas\nPara buscar en una direccion especifica, poner entre comillas la direccion, luego el criterio de busqueda y opciones\nBuscar:} > "{alias|programfiles}\Everything\database.txt"
@keydown:shift
"{alias|programfiles}\Everything\es.exe" -p {dlgstring|Opciones:\n-p:Incluir a los resultados archivos relacionados\n-n num:La cantidad maxima de resultados mostrados\n-i:Realizar una busqueda sensitiva entre mayusculas y minusculas\n-w:Busqueda por palabras completas\nPara buscar en una direccion especifica, poner entre comillas la direccion, luego el criterio de busqueda y opciones\nBuscar:} > "{alias|programfiles}\Everything\database.txt"
@keydown:common
{alias|home}\dopusrt.exe /col import /clear /nocheck "Everything" "{alias|programfiles}\Everything\database.txt"
Go PATH=coll://Everything NEWTAB=findexisting
Now this is the problem:
The problem happens in my USB DOpus, because first I need to know if Everything is running, if not I have to copy the Everything folder from my USB to /programfiles. Then use the aobve command. So I make this button (in DOS mode) but it's not working:
@runmode hide
tasklist /FI "IMAGENAME eq Everything.exe" 2 > NUL | find /I /N "Everything.exe" 1 > NUL
if "%ERRORLEVEL%"=="0" goto search
Copy FORCE "{alias|home|\}Apps\Everything" TO "{alias|programfiles}"
"{alias|programfiles}\Everything\Everything.exe" -startup
{alias|home|\}Apps\sleep 5
:search
@keydown:none
@keydown:shift
@keydown:common
Can someone tell me what I'm doing wrong?
This is what I want:
See if Everything.exe is running:
IF yes, then do a search.
IF not, copy Everything folder from the USB. Then running, wait 5 secs (with the sleep.exe utility from Sever 2003), then do a search.
Hope someone can help me with this...
Thanks.
