I created for my script a dialog with two listboxes. The first listbox can grow in height and width. Below is a second listbox which can grow in height and width and shall move in Y.
If you resize the dialog in Y the dialog does only scale accordingly to the height increase of the first listbox, but ignores the movement (or height increase) of the second one.
I assume both listboxes grow in Y accordingly to the height change of the dialog? And it would be necessary to split up the height increase of the dialog two both listboxes.
Picture before rezising:
After Resizing:
If you want to reproduce it: Select any archive + a non-archive-file and use this button (hint: if you use dual display mode choose "delete no archive" as long as it is not a test archiv; in single display mode the archiv will be extracted and if the target folder already exists it will be renamed)
Extract V2.dcf (37.9 KB)
