Direct Folders Middle Click on a two button mouse Nooooooooo
Is there any way to change this behavior???? I have a two button mouse and am not going to purchase a three button mouse to use direct folders.
If there is no way to change this Directory Opus will no longer be installed on my computer.
Anyone have any idea what this means?
I don't know Jon,
Perhaps it's very simple.
It may be that the author's expectations of Directory Opus have been disappointed,
Maybe the author doesn't yet know about Power Mode or even the Control Key.
[quote="deadkatz"]Is there any way to change this behavior???? I have a two button mouse and am not going to purchase a three button mouse to use direct folders.
If there is no way to change this Directory Opus will no longer be installed on my computer.[/quote]
Not sure what you want to do but if your mouse has a wheel then it's a three-button mouse: Push the wheel to access the third button.
With some mouse software/drivers you have to explicitly set the wheel-button to "Middle Button" as it's sometimes set to something else by default (e.g. Autoscroll or Switch Tasks).
