As some of us know it is uncertain whether Direct Folders will be adapted to DO v11.
Personally I don't like Listary as half of the features are already integrated in DO and the other half I don't need.
As an [almost]-replacement for Direct Folders I tried Folderspopup 2.0.1 which now supports DO v11. Folderspopup is an Autohotkey script and its sources are available on github. At a first glance it seems to work well but I didn't tested it in depth. So any comments are welcome.
Thanks
Matidio
PS: I am not affiliated with Folders Popup
