As the title suggests, when I set directory opus as the default file manager, I can't capture the folders that peazip opens after unzipping!
The peazip still opens the folder from explorer. Is there any solution for this please?
PeaZip probably explicitly calls FE.
Dear Alexander, thank you very much for your help, this seems to be a peazip problem, I will contact the developer of peazip and try to get him to fix it!Good luck with your work!
