Directory Opus starts with wrong tabs
I use DOpus as the explorer replacement.
When i reboot my pc or when dopus just is closed and i open a folder with the execute dialogue (e.g. shell:startup) then all the previously open tabs from dopus on the left side are gone. the ones on the right side stay open.
Make sure Preferences / Launching Opus / Explorer Replacement / Open all Default Lister tabs when opening a new window is turned on.
