Is there a way to use @disablenosel also for menus? Actually you can disbale only the buttons within a menu, but not the menu-button itself.
Simple sub-menus can't be disabled, only the things within them.
A button-menu (as in a clickable button which runs a command and also has a menu attached to the drop-down arrow on the right of it) can be disabled, but not a simple menu-only menu.
Ok, thanks.
