# Disconnect Dopus from Control panel
**URL:** <https://resource.dopus.com/t/disconnect-dopus-from-control-panel/16824>\
**Category:** Help & Support\
**Created:** [December 21, 2013, 7:31pm UTC](https://resource.dopus.com/t/disconnect-dopus-from-control-panel/16824 "2013-12-21T19:31:17Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![homedoc](https://resource.dopus.com/letter_avatar_proxy/v4/letter/h/c68b51/32.png) [@homedoc](https://resource.dopus.com/u/homedoc)\
**Post date:** [December 21, 2013, 7:31pm UTC](https://resource.dopus.com/t/disconnect-dopus-from-control-panel/16824/1 "2013-12-21T19:31:17Z")
</div>
Hi there,
This is a total newbie question, I know. But I cannot figure out the correct search terms to find the info I need in the help file or the forums.
When I click on the icons in the "Network and Sharing Center" in Windows 7, Dopus takes over and opens the items in a Dopus lister rather than the way Windows opens them. I think I have run into this same issue in previous versions of Dopus. I would like to disable this feature for all Windows system screens and functions.
I went through Dopos Preferences carefully, but I cannot find switch or button I need to do this. Can someone please give me a little help here?
Thanks,
Homedoc
**Author:** ![Leo](https://resource.dopus.com/user_avatar/resource.dopus.com/leo/32/69732_2.png) [@Leo](https://resource.dopus.com/u/Leo)\
**Post date:** [December 22, 2013, 1:06am UTC](https://resource.dopus.com/t/disconnect-dopus-from-control-panel/16824/2 "2013-12-22T01:06:19Z")
</div>
Opus is probably set to run in [compatibility mode](https://resource.dopus.com/t/windows-compatibility-settings-installer-says-xp-sp3-is-required-on-a-later-os-version/11352/1) so that Windows is telling it it is actually on Windows XP (or earlier) when it is not.
