Display as a Web Page
Hello,
I'd like to know if it is possible to display a lister as a web page (like the same option in the windows explorer.
In windows Explorer, this option inserts a zone where some details (about folders or files) can be display.
Example : for a folder, you have the name, under it's indicated if it's about a folder or a file, and under the last modified date.
Is it possible with DO to have a kind of zone identical ? I don't speak about the informations I described (name, date, etc ...) but the zone.
Thanks for your answer !
Cyrillle
Opus doesn't have this, but allows you to customize the tooltips which are displayed when you hover over files and can also display most of the things that would appear in the pane directly as columns for all items instead of just the selected one.
Viewer plugs can also run in a pane and display information but, at least right now, they're more geared towards showing image and video files.
Personally, I've always turned off the pane as it uses a lot of space to display a small amount of information that, for me, is shown better in other ways. You haven't really said what you want the panel for, though, so maybe it's good for whatever it is you're missing.
