Display "Group"bar possible?
Is it possible to show a bar with the diffirent groups (Folder Tab Groups), is switching is much easier then rightclicking?
grtz,
Mierzoet
I did fing the "go togroup" icon.
but I would like to see a whole bar, showing all the groups, like the tab bar.
Create a button which runs this command:
Go TABGROUPLIST=icons
When you exit Customize mode the button will turn into a list of your tab groups.
Oke, that worked!?
Is it now possible to show the names of the groups, in stead of showing a number of icons, that look exactly the same which is very confusing.
Is it possible to have this bar directly under the tabbar, under the listers?
grtz,
mierzoet
If you don't want the icons just remove the =icons part of the command. Make sure the button's label is also turned on.
You can put the list wherever you want it. If you want it below the tabbar just create a new toolbar via Customize and drag the button over to it.
Oke, Thank, I now used the go tabgrouplist=keys function. Because the label no icon thing did not work correctly.
So now I have a new toolbar, showing me the name of the groups, excellent.
Only thing I now would like to see, is this toolbar, underneath both listers, under the tabs with the width of the listers.
Is this possible? I can not seem to do that.
thanx,
Mierzoet
It works fine here. Could you post screenshots of your button and the result you get?
[quote]Only thing I now would like to see, is this toolbar, underneath both listers, under the tabs with the width of the listers.
Is this possible? I can not seem to do that.[/quote]
Do you need help creating a new toolbar, or do you know how to do that but want something slightly different? I'm not sure exactly what you're asking, sorry.
Hi.
For some stupid reason I am not able to get, the icons only display, showing only icons for the groups, without labels.....
This view is "=keys":
This view is "=icons" labels only:
This view is "=icons" labels and icons:
What I would like to see, is under every lister, like the Tabbar, a Groupsbar. So I can switch easily between the groups and tabs.
I don't know how to clarify further....
grtz,
Mierzoet
Looks like you cannot do that. The labels will always be shown for the grooups and only the icons and numbers are optional.
(I assume the reason for this is so you don't end up with a set of identical icons where you don't know which is which. I take it you want that and plan to memorise which is which, or rely on the tooltips?)
If you turn a Toolbar on then, by default, it will be turned on for all listers.
(You can also turn Toolbars on for individual listers by opening them with the Toolbar command, if you use the LOCAL argument, but if you open a toolbar via any other method then it should open in all listers as you want.)
OK, so I did not make myself clear enough.
When I open a new set of listers, (dual) both of them, show a tabbar underneath itself. The tabbar being linked to the left or right lister.
So now I would like to see the groupsbar also as part of the lister, like the tabbar. And opening with a lister, so when I change to single lister, I see 1 groupsbar, under the tabbar... And when I change to duallister, I see two groupbar's. I don't want to haven another toolbar with the groups on it. I really would like to see it in the lister itself, as part of the lister, as is the tabbar.
grtz
Mierzoet
Oh, okay. There's no good way to do that at the moment. You could make a button which toggles on and off a second copy of the toolbar which is aligned on the right-hand side and click that when the dual display is open, but that's about it.
To avoid confusion, the lister is the entire window (containing the toolbars, status bar, and one or two file displays) while the file display(s) are the actual file lists.
[quote="nudel"]
To avoid confusion, the lister is the entire window (containing the toolbars, status bar, and one or two file displays) while the file display(s) are the actual file lists.[/quote]
Ah, ok.... Sorry for the confusion....
I will request this as a feature with GP Soft.....
grtz,
Mierzoet
