Hello.. I've encountered some strange behavior of DO lately.
Example: renaming a file (using F2, defined as rename inline=single):
It happens on occation, although I'm not really sure of the steps to reproduce.
Same with clicking on one item, but another gets the focus rather than the one which is clicked.
Example: clicking on MyRE.dproj focuses MyRE.tlb rather than what it should.
Before you ask, the folder in the image is a normal folder, not a library (which could have two of a file),
it seems to be the edit control which is positioned wrong in this instance.
