DO 11 Script - Set current path for application
Suppose I want to invoke a program that will operate on a file..
"C:\Program Files\SomeProgFolder\SomeProg.exe" "C:\SomeImprobablyLongPathThatJustGoesOnAndOn...........\MyFile.txt"
Is there any way, within a script, to specify the "active" path so that the file name can be supplied without its unreasonably long full path. Pseudo code:
filepath = "C:\SomeImprobablyLongPathThatJustGoesOnAndOn..........." cmd = "C:\Program Files\SomeProgFolder\SomeProg.exe" arg = "MyFile.txt" With FuncCmd .addline cmd & " " arg ' e.g. "C:\Program Files\SomeProgFolder\SomeProg.exe" "MyFile.txt" .runpath = filepath ' Set "active" path to C:\SomeImprobablyLongPathThatJustGoesOnAndOn........... .run ' Run the program with its data path set as above End With
I tried forcing a current directory change with objshell.currentdirectory to no avail. The application looks for the supplied file name in C:\Windows\system32.
Regards, AB
Just add a cd command line first.
 With FuncCmd
      .addline "cd C:\SomeImprobablyLongPathThatJustGoesOnAndOn..........."
      .runpath = filepath
   End With
Thanks. So simple... :slight_smile:
Regards, AB
