DO11: Font scale reset zoom control goes missing
I'm not sure what's causing this... I've seen it in both dual and single file display modes after initially thinking it was specific to dual-display mode...
But there are times when for some reason the new 'Reset Zoom' control that pops up in the path field (which I think is great by the way, thanks for it) when you change the font scale just doesn't appear.
I can't tie it to anything specific that I'm doing... so if anyone else notices, please try and figure out what's causing it :slight_smile:. My laptop mouse pad sensitivity goes a bit wonky frequently and I am OFTEN changing the font size unintentionally - so I quite like the new reset zoom control popping up when it needs to.
From a few quick tests, it didn't fail so far. But a nice little feature.
