When changing to Images tab, the toolbar changes to DO11.
After restoring the Opus 10 toolbar and changing to Explorer view, the toolbar are again reset to DO11.
How to make this firm for all filetypes?
Go to Prefs / File Display Modes / Toolbars, then set the Thumbnails toolbar to None.
That's probably all you need to do.
Am not sure ...
Sure I will try out the new toolbars one of these days, but right now I'd like to go for the old Opus 10 one.
Maybe the Images style is set to change the toolbars as well.
Ah - YES, thanks, solved!
RMB on tab, Edit Style, Select "Directory Opus 10" at "Toolbar"
