DO12.2 Status column and Label coulour
Something I have just noticed.
I have set up status column.
I also use Label Assignments to colour file names based on file name or Tags name.
This works OK unless there is a Icon in the status column.
Is this the correct way it works.
Have I missed a setting that needs changing.
Not sure, but did you perhaps use the "stop on match" option? If so, try unchecking it.
abr
Status don't have a stop on match
Have checked Wildcard and Label filters and Stop On Match not ticked
You could try to check the option in -> preferences -> favorites & recent -> labels ->, then the upper option of the three options available.
"By default explicitly applied labels override wildcard labels, but the Apply wildcard and label filters to explicitly labeled files and folders option lets wildcard labels stack on top of explicitly-assigned ones."
https://www.gpsoft.com.au/help/opus12/index.html#!Documents/Prefs/Labels.htm
Under
Setting
Preferences
Favorites and Recent
Labels
There is a tick box
Apply wildcard and label filters to explicitly labelled files and folder.
This appears to have fixed Label colouring.
Will have to see if it causes problems elsewhere.
abr
Thanks
Have just seen you 2nd reply
I must have been writing mine at the same time.
"Apply wildcard and label filters to explicitly labelled files and folder."
That should be the one. I still have to update my list of all the translations in the menues (using the german version here).
