DO12 - Beta 5 Column sorting
I am using 2 extra columns Tags and Comments
As seen sorted on Name column
Now when sorted on Tags column
Tags column clicked again
After a few clicks it will get the sorting correct.
If I do the sorting on the Comments column it sorts correctly every time
Is this a bug
Thanks for the report! This will be fixed in the next beta.
Jon
Thanks works now :smiley:
