I am using three commands like the following one, using status icons. As i recently found, they appear to be broken in Beta 12.0.15. Assigning those labels per menu still works, however. Since the fix list for 12.1 doesn't mention it, i assume that the issue still persists.
@nodeselect
Set Columnsadd=Status(1)
Properties SETLABEL=Flagged ADDLABEL SETLABELTOGGLE
The labels just don't show up here. All that happens, if i turn off the status column, is that the command would turn it back on. But the labels are not applied. It must have worked in the older betas, though. I was using them frequently.
Yes, i have checked that. They are there, all three of the standard labels, plus two own ones. I have also checked, if the commands would work from a button (usually i set the labels using hotkeys), which they don't.
If i run it twice, still nothing happens. As i said, things worked fine in older versions.
Yes. As i mentioned, it works from the right click menu, & also from the toolbar menu, which i normally don't use that much. Bot both work.
Good question. I am receiving some licence for the official version these days, which i require to update to the new official version.
I forgot to mention, i was chosing files, where i was sure, they did not have any previous status label. I have also turned on the label name column, to see, if maybe they are just not displayed for some reason. Which was not the case.
Sorry, i misinterpreted the info box in the version 12 installer, overlooking the part with the expiration period, which still allows me to update. I have now installed the latest version, but things are still the same.
Damn, you're right. Things are back to normal. I also figured the other keyword, "wichtig", for "important". Now i only need to find the right translation for "checked"!
Now you have mentioned it. I previously had checked, if the labels are present, but didn't think about the translations at that point, that they also have changed in the codes. Thanks @all!
