The quick filter stays on when pasting, so that after pasting a file, it may not appear in the lister.
I'd never noticed this before, is it new in DO12?
If so it would be nice to have a checkbox to disable that, next to this existing one:
Thanks!
Thanks!
I don't think it's new.
To get what you want, I think you could change the ctrl-v hotkey to clear the filter as well as paste the file.
Wow, awesome! Thank you Leo.
In case anyone is after the same thing, that's
SET QUICKFILTERCLEAR
