Great work on DO12 guys, just upgraded and although I probably only use 5% of what DO is capable of on a day to day basis, it just keeps on getting better and better.
I've noticed a small issue with the upgrade that's going to rapidly get annoying, though. It's probably dead simple to fix from my end, but I have a lot of saved lister layouts that I use for dual-pane FTP to a particular site, and now when I open one of them up, all of the columns are fine until I double click into a folder, at which point the filename column of the one I'm looking at shrinks to 47 pixels wide and I have to double click the column header to re-widen it.
The lister on the other side also changes folder but the filename column doesn't shrink on that one.
This didn't happen in DO11, so I'm not sure if it's a bug in 12? Any setting I can change?
On the default toolbars, click Folder > Folder Options and then have a look how the Columns tab is set up.
If the column widths or resizing modes (depending on what you want) look correct, click the Save button at the top and use the middle option, Save format for all folders (make this the default). You'll probably also want to turn on the two checkboxes below that, unless you have custom formats for individual paths which you want to keep.
That should make every folder look like your current view.
This video should also be useful, if you want a deep understanding of everything that's going on here:
Thanks, Leo. I've done this now. Unfortunately it's replaced the "sorted column" in my saved layouts (which was always Date Modified) but I'll just have to "reset" these as I come across them - unless there's a way of applying a folder view to all folders just in saved lister layouts?
