DO12 - Folder format lock symbol showing "Default Format"
If I got this correct, the "Default" folder format is gone, it's been replaced with "User Default" and "Factory Default" term-wise. Good move! The format-lock symbol in the status bar still shows "Default Format" for the "User Default" though, my feeling is, this should read "User Default" as well?
