Is there any way of telling DO12 to save the state of the ignore extension checkbox when the rename dialog closes? Generally speaking I prefer to keep ignore extension turned off, but every time I re-open the rename dialog it's ticked again.
You can save a preset and then change the Rename button to load that preset.
Please link your account if you need step-by-step help.
Any way of telling the preset to not set the "old name" to "*" in Standard Wildcard Mode, but to load in the actual filename being renamed?
I guess this comes down to the differences between DO11 and DO12 when using the Advanced rename dialog to rename multiple files.
