DO12 - Rename Panel - Scripting Pane - Ctrl + S not working
When working on a script in the rename panel, if the cursor is in the scripting text area, Ctrl + S doesn't seem to work.
I have to go to the "Preset Management" icon far, far away and select "Save".
Is anyone else experiencing this?
This is still the case for me in 12.1 -- anyone else?
To clarify what I'm talking about:
  • In the rename panel, Ctrl + S works on the left side of the panel ("normal" settings)
  • Ctrl + S does not work from the scripting box part of the panel
If it's working for one of you, please let me know, that will mean it's a weird keyboard thing on my end. Thanks!
Thanks, this is on our list to look at.
