Docked viewer pane is not updated on tab navigation
I'm wondering about the update behaviour of the viewer pane:
Sometimes it is updated (e.g. when entering a folder the viewer pane is updated to the content of the first file) but sometimes it isn't updated (e.g. when changing focus).
To be honest I feel really confused that the viewer pane is updated when I create a new tab but it is not updated when an old tab is closed!?
This behaviour occassionally has led to some mis-interpretation on my side because if I come back to DOpus I can not be sure that the current file (which has focus and selection) is actually displayed in the viewer pane. Instead I have to press space to trigger a manual re-selection of the already selected file. That feels some kind of inconvenient. In the past I have struggled with this behavious multiple times, because in our repository we have many very similar looking files and it's easy to miss that the viewer pane shows a file that may belong to an other tab which was sent to the background or was closed minutes ago.
I would really appreciate to see this fixed to let the viewer pane always show the content of the focussed (and selected) file. :thumbsup:
It updates when something new is selected in the active file display. (Changing tabs doesn't cause a new selection, just changes which file display you can see.)
We might change it at some point so that changing tabs or activating the other side of a dual lister also triggers the viewer to re-evaluate which file it is showing, but that's how it works right now.
Ok, so it is intended and it is not a bug but anyway it feels like a bugI :wink: Thus I would be so happy to see this fixed.
